Do a vinegar flush Pour a quart of distilled vinegar into your washer and using Hot water wash let your machine run through a wash and rinse cycle. The vinegar will cut through suds .. also wipe down the rubber gasket with a 1/2 vinegar /water solution to clean the gasket
If you have a water softener or very soft water, soap will suds up more than if your water is normal or hard, so you'll need to use less than recommended. Obviously soap breaks down the dirt, but the dirt also breaks down the soap, so if your clothes are not very dirty to start with, you'll need less soap than if they were more dirty. Soap can also be stored in laundry like towels and cleaning rags and when combined with the laundry soap will suds more. You can try raising the leveling legs in the front to tip the washer back. This will help the water drain back into the tub instead of pooling on the boot. You can also try using the 'extra rinse' option. Keep cutting back on how much soap you use until your laundry is not as clean as it should be. You might be surprised how little soap you can use!
