If you are using Vista, I seriously doubt it will allow you to use the image. Normally any Windows program will not allow you to do something like that from within windows. The system image backup is meant to restore the image, which means completely copying and overwriting everything on the hard drive - which Windows will not allow while in use. If you boot from the Vista setup disk, then you should be able to restore the disk from there.
SOURCE: Hard drive
when you change a hard drive from one PC to another you have to do a fresh install. The problem is caused with the registry. In other words, the hard drive remembers where is was conntected to and records all of the hardware on your PC to a sepecial datebase called a registry, when you start it up it looks for all of that hardware and if its not there it fails to boot.
[email protected]
SOURCE: Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
