Microwave Ovens Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kitchen aid over the range microwave Model No; KHMS105EWH-0 stop heating.
Anonymous
Level 3:
  • KitchenAid Master 43,501 Answers
  • Posted on Feb 03, 2011
Anonymous
KitchenAid Master
Level 3:
Answers
43501
Questions
0
Helped
10835118
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Kitchen aid microwave blow 20 amp fuse on start.
Hello James
Having a 20 amps fuse is a bit high in todays standard as 15 amps fuses are recommended these days - they do not want too much current to go through the house wires.
Better to buy a new microwave as this microwave could burn down your house.
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
1helpful
Kitchen Aid microwave over will not heat
Common cause of this problem is transformer fuse blown.check the fuse.if fuse is ok, then replace magnetron
1helpful
Kitchen Aid microwave KHMS105EWH-0: I started to heat a cup of coffee, it momentarily interrupted power to the kitchen, fluorescent lamps went out, then slowly came back on. More below.
Because of the loud snap you are hearing, my guess is you have something shorting out in the high voltage section of the microwave. I'm surprised it is not blowing the internal microwave fuse yet. Average repair cost depending of what part it going bad is approximately $150 to $200. Considering the age of your micro my suggestion is put the money towards a new one.
My kitchen aid micro wave stopped heating the food. Everything seems to be working. Model Khms155L. I want to replace it but it is no longer in production. Is there a replacement model that is an exact...
Take your measurements and compare them to the measurements from various microwaves online, then go to the store that has the same measurements. I wouldn't use the microwave for fear of a fire.
The power is on to my Kitchen Aid microwave convection oven, but the microwave will not heat up? Any ideas as to how I can fix this?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
I'm looking for repair manual for range made by Kitchen Aid
web search-kitchen aid range manuals- or -kitchen.manualsonline.com
2helpful
4answers
3 yr.old Kitchen Aid microwave KMS155LSS4 - Unsafe has a mind of
This is an over the range microwave if I guess correctly. ( I couldn't find the model at KitcheAid)
The computer board is no longer sealed and has gotten wet from steam coming off of food being cooked below it. You need the computer control board replaced. My parent's GE over the range microwave had similar problems a couple times.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
