you have to format your hard drive using a third party disc to erase everything on your hard drive During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart once you have started the format process with your operating system disc at some stage it will ask you what format do you want this operating system in ntfs or fat/fat32 hope this helps
Open My Computer icon on the desktop. locate the hard disk you wish to format in FAT32. Make sure is not your main drive where windows was installed which is Drive C: Right click on the drive you want to format and select Format, a formatting window will pop out, there you see capacity which is the size of your hard drive,File system, and so on. Select the drop down menu under File system where we have NTFS and FAT32. Set it to FAT32. Under Format Options, Select Quick format and click Start. A warning message will pop out Click Ok to proceed. Wait a moment until the formatting is complete. Good luck.
SOURCE: How exactly do you format the HDD as "FAT32"??? i
Open "My Computer".
Right-mouse click on the icon for the MyBook.
Choose 'FORMAT'.
Choose 'FAT32'.
Click OK to start the reformatting.
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
