This sounds like a driver issue .... after plugging in the USB dongle, go to the Control Panel>System and Security>System and select Device manager. After Device Manager opens up you should see "Keyboards". toggle open the triangle, to the left of the word "keyboards", and you should see the 2500 listed. If not, right click on the keyboard listed and select update driver software. Then select "Search automatically for the updated driver software". If a new driver is found, it will ask you if you want to use it. If not, try uninstalling the driver that is there and re-booting your computer. Then when you plug in the USB dongle it should automatically install the needed driver.
SOURCE: keyboard installation instructions, presario 2500 laptop
hi
this might give you some idea on how to remove the keyboard
Compaq & HP Notebook Optical Drive Installation Guide
riz.
SOURCE: Resolving installation problems with GrandTec EyeSeeAll RFC-3000 webcam
I WANT TO INSTALL A ZENITH WWEB CAM PUT DONT HAVE TH SOFTWARE HELP PLZ....
SOURCE: Bluetooth keyboard will not pair to FSC Celsius Mobile H
https://bugzilla.redhat.com/show_bug.cgi?id=114489
There is a patch for that problem.
SOURCE: i need a new dongle as i broke mine, did buy a
You can order replacement parts directly from Microsoft.
U.S.
Customers can contact the Microsoft Order Desk at: (800) 360-7561
(Monday through Friday, 8:00 a.m. to 7:00 p.m. Eastern Standard Time)
SOURCE: logitech dinovo bluetooth keyboard passkey issue
You entrer your own passkey after hitting the connect button on the KB.
