SOURCE: how to recline
Hi, the quinny zapp does'nt recline it is as it is. It is however possible to attach a maxi cosi carseat if you have adapters. The quinny buzz is the one that reclines, hope this helps.
SOURCE: how do i attatch the quinny zapp xtra seat to the quinny zapp frame
Yes the new seat unit can be used with old zap.You remove the fabric seat (look on u-tube if you don't know how)the new seat unit then fits on to frame via the addapters that come with the xtra seat unit, at the point where the car seat addapters fit.There is a large push button on the top of the seat unit which you push in to recline or sit up the seat, and a little one too next to it, that needs to be pushed away from the larger one, while you hold the large button down when you want to remove the seat unit.I found fitting the xtra seat very easy.To fold the zapp you Must remove the entire seat unit as it won't fold with it on, unlike the old one.
SOURCE: i have the old quinny
If you have ordered a standard Quinny Zapp seat fabric there are no adaptors required as it fits exactly the same way as your original seat fabric. If you have ordered a Quinny Zapp Xtra seat unit it should come complete with two metal recline adaptors to use it in your chassis. If it does not, speak with your retailer.
Hi carrot1410, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what country are you in?
