Hi
im fraidoon shiravani from iran
i buy a sharp ar-5516 machin
this machin developer was empoty
i wont to chang that
after chang no tern off that hilight
i wont to send me that code to tern off that high light
tanks
The machine knows you are using refilled / counterfeit toner cartridges, usually on a leased machine. Buy one factory replacement, swap your fakes back in at a later date. OR is is the Developer Unit, not the cartridges.
yes ar021FT toner compatible for your 5516. when replacing the developer:1) pull out the toner cartridge,2) pull out developing unit with 1 screw (blue),3) in developing unit remove 2 screws (blue) to open its top cover,4) drain d unit and replesnish with new developer. do procedure 4 to 1 to return. Good luck.
You have to change your developer, you can see developer spillage inside the machine it is a common problem in this particular model. Rate this and vote for this after your problem resolved.
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate, for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Try a reset first (Press #, interupt,c,interupt, then 14 start), If it pesist, Check the drum for injury lines, the developer for inpurity and clean the toner catradge proper, the close all machine doors. Good luck.
