P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Hope, helpful.
P8 : diagnosis of malfunction outdoor unit malfunction inspected unit outdoor.
Air Conditioning Fault Codes
SOURCE: CAN YOU TELL ME WHAT THIS ERROR CODE MEANS P8
P8- Abnormal temp of out door. If new unit, check gas pressure, may be over charged. Release some gas. If existing a/c, check condenser coil- dusty- clean it. Check f.motor- less rpm-replace capacitor. F.motor mechanism locked- replace motor. If above all o.k., non-condensate gas inside. Release all gas, flush out, replace filter drier and vacuum. And do gas charging. Thanks, helpful.
