1)
If this installation was working before, the Maestro has a small
pull-out circuit breaker that lets you reset the device. This is called
the FASS Front Accessible Service Switch, located at bottom of dimmer
where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
2)
If this is new installation, then double-check your wiring and check
that load matches dimmer capacity: 600 watt incandescent or halogen,
which apparently excludes CFLs.
Some electronic devices have
shortened lifespan on circuits that are not clean. Use circuit analyzer
on nearby outlet that is on same breaker to see if line has interference.
3) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
1-800-523-9466
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
