Kenmore 62602 Electric Dryer Logo
A
Anonymous Posted on Feb 03, 2011
I have a kenmore 110 6262200 I have replace both tstats, heating coil and then taped the thermofuse wires and still no heat...
Bruce Denton
Level 2:
Sergeant:
  • Expert 273 Answers
  • Posted on Feb 03, 2011
Bruce Denton
Expert
Level 2:
Sergeant:
Answers
273
Questions
Helped
51216
Points
772
Greetings,
did you check the voltage? the machine will run on 110 volts, but you need 220 volts to make it heat..The thing to check is the voltage..I have seen circuit breakers do this. The motor itself can keep the heater off. If you have a ohm meter . check the red leads on the motor itself..remove the red wires and only check where the red wires connect to the motor. If you get a reading its ok, if not, the motor switch is bad, but, its best to replace motor.
Its possible, after checking the above, that you can't still find the problem. Then, double check that you have 110 volts between,L1 and N and 110volts on L2 and N on the terminal block in the dryer where power cord attaches...i have seen the power cord go bad as well....The timer itself can cause this same problem. This is the last thing that I can think of that could keep your dryer not heating, that is if everything else has been checked and double checked.
1helpful
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
1helpful
Kenmore dryer, heat is not coming on during any of the modes. Model# 110.76512695
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape or with an ohm meter. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
I have a five year old Kenmore electric dryer that will no longer dry or produce heat on any of the settings. Is this a heating coil/ element problem?
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside of the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
Please rate me
Dryer will not heat
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Would not hurt to check again this one...Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Kenmore dryer dries cold.
Good Luck,
Hope this helps
Kenmore Dryer Model 86874800 68748 How to
Good Luck,
Hope this helps
Kenmore clothes dryer, no hot air coming out, model 11072822101
Good Luck,
Hope this helps
1helpful
Kenmore elite dryer runs but there is no heat, not drying clothes
Good Luck,
Hope this helps
Kenmore dryer,timer replaced 3 yrs ago,motor rebuilt one year, does not heat
Good Luck,
Hope this helps
I have a Kenmore model 96283110 runs, but no heat
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
