SOURCE: tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
SOURCE: internal antenna
It sounds like the TV justs has a insufficient internal antenna system. If you can put an external antenna on this sytem do so just to test it.
SOURCE: red pixels
you will need a professional to service your tv. basically the tech needs to connect an osciliscope to the y susatain board and adjust the voltages on this board. most plasma tvs will need this done about every seven years because electronic components tend to lose their value over time. this is called electronic drift.
SOURCE: I don't have cable, so I bought a small antenna to
It's all digital now - don't forget.
You need to switch from cabel to antenna first.
Play around with menus - it has to be there. Or just do areset if there.
