Try to log into SafeMode using built-in administrator account (hope you did not password protectit,), then reset your other password in safe mode as follows: 1. Click Start button, and select Run 2. Type "control userpasswords2" 3. Select account you want to reset passwordfor and Change password on it If failed, takeadvantage of Windows Password Recovery to create a password reset disk withCD/DVD or USB flash drive. 1. Get Windows Password Recovery from http://www.anypasswordrecovery.com/ 2. Burn a password reset disk with CD/DVD orUSB drive and the program 3. BIOS settings 4. Reset lost password with the burnedpassword reset disk.
Crack Dell Laptop Password ' Want To Hack Into Dell Notebook Computer / PC?
In Windows XP, you may create password reset disk. If you forget your password, you may logon to the computer by using your password reset disk. With a password reset disk, forgetting your password may no longer be a crisis. You can also use third-party software applications for password resetting in Windows XP system.
This method is easy enough for newbies to follow - it doesn't require using the Recovery Console or any complicated commands. And it's free - I mention that because you can pay two hundred dollars for an emergency download of Winternals ERD with Locksmith which is a utility for unlocking lost Windows passwords. See here http://www.winternals.com/products/repairandrecovery/locksmith.asp
ERD is an excellent multi purpose product, but you should know it is not a necessary one if you have a healthy system and your sole problem is the inability to logon to Windows due to a forgotten password. Not necessary because you can easily change or wipe out your Administrator password for free during a Windows XP Repair. Here's how with a step-by-step description of the initial Repair process included for newbie's.
1. Place your Windows XP CD in your cd-rom and start your computer (it's assumed here that your XP CD is bootable - as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be "Press any key to boot from cd"
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like "If one of the following Windows XP installations is damaged, Setup can try to repair it"
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically - you will see a progress bar stating "Your computer will reboot in 15 seconds"
9. During the reboot, do not make the mistake of "pressing any key" to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windowsis highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devicesprogress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you've made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
Which password did you forget
If you have a repair disk, of course you can try it to crack Windows 8 password. But if you don't have maybe you can consider using Ophcrack. Most time it is helpful but cannot guarantee 100% successful reset. Above all, the last one should be the best method for your Windows 8 password reset. Another safe and effective software you can try, Anmosoft Windows Password Reset, which I have used and you can visit from:http://www.resetwindowspassword.com
To reset Dell Windows password, the best and most effective way can be reset disk or software. If you have a reset disk you can recover directly. If you don't have you can use your USB to download Windows Login Recovery, which is reliable and safe reset software, and you can download from:http://www.windowsloginrecovery.com
