The control panel start/resume button is NOT working nor are the Heavy Duty, Normal, Light/China, Quick Clean-up or Riinse only. The Pro Scrub light the Sani Rinse light and the Cancel button all work. The Dishwasher does not turn on, however when I depress the cancel button, the 2 minute drain is activated. HELP!
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there. Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door, Push Hi Temp Scrub button, Push Saver Dry button, Push Hi Temp Scrub button again, Push Saver Dry button again, All lights on control panel will come on. Close dishwasher door, Push Baked on Cookware or Normal Button. Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
bellman, on this model I believe you can clear the fault by pressing high temp scrub--air dry--high temp scrub--air dry in that order. Your normal cycle on this dishwasher is approx 97 minutes without the thermal holds, (pauses to heat the water to proper temps.) So of course it's going to go over 97 minutes. This is for heavy soil. Light soil, approx 89 minutes. Some models have a soil sensor, some don't. If the sensor is out of specs..it could add to long wash times. The heater may in fact be the problem, he needs to check it. The heater runs through the nuetral side of the door switch so you want to make sure the switch is closing and the dishwasher is level and secure. He also wants to check out the resistance of the thermistor, should read 48 to 52K ohms at aprox. 75 degrees. Catriver..post back.
