Standard/ Energy Save and Store/ Dynamic option i\would appear on first time tv setup and if you want to get that option again, please reset tv on factory default settings, after that you will get initial setup screen to select either Store/ Standard option.
To restore factory default
Caution: When you restore factory default, all settings including password will be cleared and reset to default (the password is reset to 0000). So make sure you do want to reset the settings to its original factory condition before you perform this operation.
Navigate to the Lock menu and input the correct password to access.
Press Up or Down button to select the Restore Factory Default item, and then press >> or OK.
A message appears prompting you to confirm again.
Use Up or Down button to select between YES (to reset) or NO (to cancel) item, and press OK to confirm.
Press MENU to return to previous menu. Press EXIT to close the menu directly.
Hope these info will help you.
Thanks.
This power saving feature reduces the backlight
brightness level. The options are:
• OFF-the feature is off and the power consumption
is normal.
• LOW-power saving level is low and the backlight
brightness level is lower than normal.
• HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
Thanks.
Thanks
