Kenmore 44072 Front Load Washer Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It just recently started making banging noise during the spin cycle it is 6yrs old and i called sears but the warranty has expired and it cost $100 for a techican to come in for 10 min
Gerry Harvey
Level 3:
Genius:
  • Kenmore Master 1,482 Answers
  • Posted on Feb 02, 2011
Gerry Harvey
Kenmore Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
378868
Points
4533
Check you 4 springs are ok 2 top 2 bottom with struts...Next make sure concrete weights are not loose also the machine is level...if excessive play on inner drum then this says possible bearing problem....
4helpful
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
3helpful
2answers
Our Kenmore Elite Oasis that we purchased over 3 years ago started to make incredible noise during the spin cycle, so loud you can barely hear yourself think. We had a repairman from a Service Company...
Yes, Sears repair just ordered one for mine. Entire tub due to bearings gone. Also just over 3 years old and ext warranty ran out in June. Final inspection before warranty was scheduled in June 2010. July the bearings are gone. Hmm wonder how they missed that? Anyway if you call for service, ask about the maintenence plan. Its way cheaper than labor and tub and u have another year for more issues with this piece of junk washer.
1helpful
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
1helpful
2answers
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
1helpful
2answers
Frontload washing machine makes noise during spin cycle
call sears 1 800 4myhome they can walk you thru some troubleshooting. First thing pull back the rubber ring between door and barrel to see if anything like pens etc feel into the gap underneath. If not call for troubleshooting. Get a plan with sears then wait 30 days and call in the problem. Fix will cost less.
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
2answers
Kenmore Front Load Washing Machine
warranty is free of charge the only they may charge is material they use .
2answers
Loud noise when spinning
the only part that makes a loud noise is your bearings m8 other than that could be a bra wire stuck inbetween your drum and casing m8
2helpful
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Alexander
vince
