U nead a bearing kit ie 2 bearings and a seal put ure 2 hands inside the drum thumbs on outside give a squeezing motion if the inner drum moves the bearings r gone
I would suggest that the drum is out of alignment because the main bearings have failed, or the drum shaft has collapsed due nto corrosion.
Spin the drum by hand, and listen for any noise, there should not be any, and see if the drum rotates centrally in relation to the outer drum
