Question about Life Fitness Exercise & Fitness
Where is battery located for LifeFitness' Lifecycle 9500HR
  • Anonymous Mar 23, 2014
    battery location? is this a standard battery?
  • 2,361 Answers
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
The 6V battery will be within 12" from the pedals. Where is battery located for LifeFitness' - mustgo_52.jpg
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Posted on Feb 02, 2011
SOURCE:
Looking for location of battery in LifeFitness C9i exercise bike. (C7i battery was in control panel, earlier models may have been in the base.) Thanks!
How do replace the battery in Lifecycle C9i exercise
The web site above states the following:
The 9 volt battery for the display on the bars of the bicycle goes in underneath the display (on the bottom of it).You can also see the 7th page (pages are not numbered, simply scroll to the 2nd to last page) of the manual at the link below to see where the battery installs:
https://www.lifefitness.es/static-assets/document/manuals/C9iAssemblyInstructions_12-07-05.pdf
Feb 16, 2018 | Exercise & Fitness
The Fit Test and Fat Burn do not light up as an option on my Lifecycle 6500HR bike, they used to work now they don't.
This really sounds like there is a problem with your console. You might consider contacting LifeFitness for replacement options and or further troubleshooting. 1-800-351-3737 is the contact phone number for them directly.
Mar 23, 2014 | Life Fitness Nut Lock, Cranknut, Lifecycle...
My lifecysle 9500hr the start button does not light up
I recomend that you read your instruction manual,and check the section troubleshooting. If you do not have go to download to the next web page: www.fitness.manualsonline.com or www.iconservice.com for FREE.
God bless you
Aug 31, 2012 | Life Fitness Club Series Lifecycle...
The Lifecycle 9500HR does not come on--where is the battery?
I have the same issue. Can someone tell me where the battery is located? Is it in the control panel or in the base? Are replacements easy to find?
Sep 06, 2010 | Cycling
How to replace lifecycle 9500hr battery
The battery located at the front bottom of the bike.
Remove TORX screws from the right side and bottom cover (as if riding)
Move the cover aside to locate the battery
Remove two slot screws holding the battery
Replace with original,or alarm type battery (use plastic ties to secure)
[URL=http://s1059.photobucket.com/user/2750709/media/Mobile%20Uploads/952BFE63-B54A-417D-9B5E-F7C2706326D7.jpg.html]http://i1059.photobucket.com/albums/t436/2750709/Mobile%20Uploads/952BFE63-B54A-417D-9B5E-F7C2706326D7.jpg[/IMG][/URL]
Aug 18, 2010 | Cycling
Lifefitness 9500hr recumbant exercise bike dead
This unit takes a special 6 volt battery. The battery is in one of two places. First place to look is under the unit. If you lay the bike over on its side there is an opening in the covers. If the battery is not there then you will need to take one of the side covers off. When you get the side off you cannot miss it. The battery is black with three cylinders. You can get the battery from sportsmith.net.
Mar 15, 2010 | Exercise & Fitness
I have a lifecycle model 9500HR, will not turn on.
Some of these units have the main battery ( 6v @ 2.5AH ) inside the bike frame and a 9v in the backside of the upper console
Feb 18, 2010 | Exercise & Fitness
I was told that my lifecycle 9500hr wasnt turning on because of the alternator. I replaced that and the display still wont turn on...any ideas of how to fix this????
You were probably steered wrong. I would expect the battery is the problem.
Use a voltmeter to check voltages.
If the battery is fully down, the alternator MAY have to have the field "flashed" to start generating.
In an automobile the current throu the alternator "idiot light" DOES THIS AUTOMATICALLY.but for your lifecycle I don't know how they do that unless the alternator uses permanent magnets.
Oct 23, 2009 | Veritas Data Lifecycle Manager Win V5.0...
Manual for lifefitness 9500hr treadmill old modle
Just call Life Fitness and they will send you one via e-mail attachment.
(800) 351-3737 between 8 a.m. and 5 p.m., CT Monday through Friday.
stephen
Aug 01, 2009 | Life Fitness 9500HR Next Generation...
Exercise & Fitness Logo
4,257 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
