SOURCE: personalize outgoing message
Here is the uniden website page for cordless phone manuals. Just locate your model # and click on it. It will download it in pdf format.
http://www.uniden.com/index/manuals_results.cfm?cat=1
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Testimonial: "thank you very mucy "
SOURCE: How do I set up my Uniden Dect 6.0 personal message???
Setup configuration file. If WordPress can't find the wp-config.php file, ... I keep getting an Error connecting to database message but I'm sure my configuration is correct. ... A web search will find recent instructions for any environment! ... Configure the Database: After accepting the terms, if you need to ...
Setting a Personal Security Code (PIN)
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal
Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code"
followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press
menu again."
Note: The PIN code is set to "80" at the factory.
