SOURCE: Non recognized Kingston pendrive 4 Gb
i bought a kingston 2 GB pen drive. computer does not recognize. device manager says drivers are not installed. but it works in safe mode. kindly help
SOURCE: Can't Reformat Kingston DataTraveler 2.0 USB memory stick
Use any linux bootable distro, like puppy (100 MB ) Slax ( 200 MB) or ubuntu to make a live boot, or use any pc which has linux installed can format your USB to its full capacity.
SOURCE: Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Testimonial: "It was great to get a advice right away! Thanks! I'll get another cable to try if it works. "
SOURCE: I have bought a Kingston 8 GB data traveler 100
Hi, You just need to plug the device to the USB port on your computer and a new icon for your flash drive will appear in the My computer folder. You can use that as any other normal drive on the computer.
Let me know if you need any further help
Testimonial: "Much more helpful. Thanks. I am dragging folders to the device to save them. Thanks again. Regards, Larry Johnson Miami Gardens, Fl"
SOURCE: usb devics not recognized
try it to a known good USB port. if still unsuccessful connect it to another PC that has a known good USB port. if still unable to work. you might have a bad USB stick..
Hope it helps!
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
