i closed a window and the same window kept opening again and again with out me pressing anything. i ctrl alt deleted so i could restart it. it never came back on so i unpluged it to let the battery die. when i pluged it back in the red light blinked like it always does when it isnt on. i pressed the power button and it turned green and it made noises like it does when it starts, the webcam even blinked like it usually does. the screan never comes on though. i put in a cd and it makes the same sound it always does, the music doesnt play and the screan never comes back.i closed a window and the same window kept opening again and again with out me pressing anything. i ctrl alt deleted so i could restart it. it never came back on so i unpluged it to let the battery die. when i pluged it back in the red light blinked like it always does when it isnt on. i pressed the power button and it turned green and it made noises like it does when it starts, the webcam even blinked like it usually does. the screan never comes on though. i put in a cd and it makes the same sound it always does, the music doesnt play and the screan never comes back.
AnonymousJan 19, 2009
hey guys could you please tell me , where can i buy a motherboard for the aspire 5520, mine just burned because of water..
Check if dvd drive will eject if not if it doesnt - try another socket if still gets nothing - change fuse in plug if same - try another power adapter (preferably from same manufacturer and model) If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
When I turn on my Acer 6930 the screen will stay black but all f the buttons come n to show tht it is running. Nthing happens it is just a blank screen. an anyone help me with this issue?
Simply press the WiFi on/off key (it's the first key from left to right, between the "Power" button and the laptop's keyboard). A message should appear on the screen telling about the WiFi adpter's state (on or off).
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Pull The Battery... Unplug The AC Adapter....
Press and Hold The Power On Button For 30 Seconds...
Reinsert The Battery, Plug In Ac Adapter... Attempt to Power On..
Also Try Removing The Battery And Powering Up Using The Power Cord Alone.....
If Still No Power.... Remove and Reseat The Memory Modules...
Still No?
You'll Next Need To Check To See If The DC Jack Is Faulty...
If It's Faulty, You'll Need To Desolder It, Clean The Board, Resolder a New One ON....
Check The Heatsink/Fan Assembly...it might be clogged...
Still No?
Possibly Faulty Video / GPU Chip....Or a Shorted Out Motherboard..
TAKE OUT BATTERY, REMOVE MAINS SUPPLY, HOLD POWER BUTTON DOWN FOR 30 SECS PUT POWER SUPPLY IN ONLY DO NOT PUT IN BATTERY TURN ON LAPTOP NOW PUT IN BATTERY
Hi there. The keyboard toggle you are using is the correct one. Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
can you go to bios? load default setings in bios, or optimized settings, then try... when something like that happens i usully pull out batery on mother board, than wait about few seconds and pul it back in... bu that is to much work. try above,, and let me know
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
i need to buy another mainboard now
thanks
here my email [email protected]
