These are prone to power spikes...and for that reason have a fuse located on the power supply board...known as fast blow fuses...which are glass and easy to see if they have blown..sometimes all you need to do is replace the fuse on the rear of the unit if you can locate a fuse cap...just unscrew and replace....Always unplug televisions and audio equipment and routers during power outages and thunderstorms as a preventative to blowing psu panels on electrical devices connection to your house mains for this reason .
SOURCE: Region Unlock code for Philips HTS 3152
Power on the system
Eject the disk tray
Press Stop for around 2-3 seconds
Type in 7,3,4,4,6,6,0
You should get a message saying your player is now Region 0.
SOURCE: I'm looking for the region cod, the Philips HTS 3544
TURN ON THE PLAYER
PRESS OPEN/CLOSE
USING REMOTE PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL APPEAR. PRESS "0" TO UNLOCK ALL.
SOURCE: plays cds not dvds
Hai,
This is is due the lense and motor section problem, to resolve this issue you need to replace the lense and motor set.
SOURCE: I have a Philips HTS
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
