Good luck getting a question on a 'balistics table' answered in a forum on "table saws".
Never know though. Seems like a good place for overlap of interest.
That bulb MAY require a 12V. power supply.Inside the fan housing. They overheat and just go bad.
The socket may have overheated and damaged the contacts that the bulb must have. The bulb has a number on it and that is the key-ask the hardware person about that bulb. "Google" the number,also. That's easier.
Your Balister is shot. google balister on this model, or save yourself
some time, stick it in a corner as a giant paper weight as I did and
file a complaint with conumer affairs, they are online.
If it is wired correctly,the only thng left is the tomestones, the contacts that the bulb connects to. Try this ;switch the two wires from the one bulb at the ballast to the other bulb on the ballast. If the other bulb now lights then the new ballast is bad and need to be exchanged.
you can get the service manual at the following link. Its under the mitsubishi category listed as the V26 DLP service manual. http://servicemanuals.vstore.ca/
A Ballast is a circuit that provides voltage to Lamp. Ballasts are only used with TV's with a Lamp. According to your model number this unit does not use a lamp. That model number uses 3 rear-projected CRTs. The most common units with a ballast would be a DLP HDTV.
The Model number you specified HCN4226W is a unit made in 2003. However you stated in your subject line that this was a Samsung unit from 2006. Please verify your model number.
