Sony Handycam Camcorder DCRSX63 Logo
Posted on Feb 02, 2011
INTERNAL MEMORY ERROR e:94:01 on my sony HDR-CX106E
Caetano Veyssires
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 02, 2015
Caetano Veyssires
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5692
Points
Oh my god, dj_relly999 you just saved my life !
I shall always be grateful to you.
5 Related Answers
dj_relly999
dj_relly999
  • 4070 Answers
  • Posted on Oct 10, 2010
SOURCE: Sony HDR CX150: while recording,
Hi! This thing happens... Please remove the battery and press/hold the power button for 10secs. while the battery is removed to reset the system. After 10secs. insert the battery, turn it on and observe how it goes. Hope this helps and thank you for using FixYa!
Jimmy Accardi
  • 102 Answers
  • Posted on Nov 09, 2010
HDR-CX150 lcd screen is showing upside down is there a way to fix this ?
Anonymous
  • 11 Answers
  • Posted on Dec 22, 2010
SOURCE: Sony DCR SX40: internal memory format error
You may have to try some video recovery software, here are some for your options. Both programs can also recover photos and music.
video photo recovery program (for Windows OS)
Mac video photo recovery program (for Mac OS X)
First of all you need to install the program on your computer (choose the right version based on the operation system you are running), then connect your camcorder (memory card or HDD) to the computer and start to recover your deleted videos.
One More Tip: Your should act as soon as possible and before the deleted videos are recovered, better not take more videos in case overwritten situation will happen.
Anonymous
  • 10 Answers
  • Posted on Oct 16, 2011
SOURCE: HI, i have a sony HDR-CX150
In this case you may have to take a try of this Sony Photo Recovery (also retrieve videos and voice memos etc). Install it on your computer and connect your sony device to make a free scan and recover the deleted items. Regards
Anonymous
  • 103 Answers
  • Posted on Feb 22, 2013
You may try a video recovery software, recommended asoftech data recovery as it helped me before. use link below to download:
Camcorder video recovery software
You may refer to this video tutorial
Video camera problems - Sony Video Camera problem
Error code 94:01 is an internal memory error. If you still get the error after reformatting the card or trying a different one, it's an electronic issue usually used by component failure and requires replacement of a circuit board within the camera.
Jul 12, 2014 • Cameras
tip
Transfer/Edit Sony HDR-TG3 1080i AVCHD Videos on Windows/Mac Sony Handycam...
Sony Handycam HDR-TG3E is a super small camera with full HD recording on Memory Stick in 2008. It includes 4GB and 10x optical zoom for capturing 1920x1080 and 1440x1080 videos. However, this camera does not include progressive recording mode, which indicates that the HD videos are 1080i. Even though it is compact camera, the audio is recorded in Dolby Digital 5.1ch. You can also take 2.3Mp stills while you are recording video footage.
Sony HDR-TG3E features:
- 1920x1080i HD video recording
- 4 megapixel still photo recording
- Dual Rec simultaneous 2.3 megapixel still photo during video recording
- Handy face detection
- Carl Zeiss Vario-Tessar lens
- ClearVid CMOS Sensor and Exmor derived technology
Videos from Sony HDR-TG3E:
Movie Format:
- High Definition: AVCHD (1920 x 1080, 1440 x 1080) in .mts filename extension
- Standard Definition: MPEG2 in .mpg filename extension
Movie Quality:
- HD: FH (1920x1080i, 16Mbps) / HQ (9Mbps) / SP (7Mbps) / LP (5Mbps)
- SD: HQ (9Mbps) / SP (6Mbps) / LP (3Mbps)
Transfer & Edit Sony HDR-TG3 AVCHD videos:
For Windows users:
Install the Picture Motion Browser (PMB) from the bundled CD in box, and connect Sony HDR TG3 to PC via USB cable. Use Sony PMB to download HD .mts videos from camcorder to PC.
For Mac users:
You can capture and transfer Sony HDR-TG3 1080i videos to iMac/MacBook Pro via iMovie after connecting camera to computer with USB cable. However, you may face problem when trying to log and transfer AVCHD videos from Sony Handycam HDR-TG3E to Final Cut Express (FCE) 4 or Final Cut Pro (FCP) 5. After transferring HD .mts videos from camera to computer hard drive, just run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-TG3 MTS converter to deinterlace .mts videos and convert .mts to .mov for FCE and FCP, if you want to edit HD videos.
Alternative way to transfer HDR TG3 videos for Mac and PC:
Just connect HDR TG3 pocket camera to computer via the USB cable, and the HDR TG3 will display as a hard drive on computer. Navigate to the HDR TG3 hard drive to access the memory stick.
Tips: Sony Handycam HDR-TG3E is the model for Europe, and Sony Handycam HDR-TG1 is the model for US.
on Jul 14, 2010 • Cell Phones
HDR-cx360V - E:91:01 - Error does not go even after reset/power off.
this is a manufactures melfunction.sony will fix it for about $294 or give 15%of on a new one.buyer be ware.
1helpful
NEED TO TAKE OFF WRITE PROTECED ON SONY SDHC 4GB..
There is red colored switch aside ur memory card. check it if its locked mode,then push it upwards and make it visible.
Where is my sony dsc-w310 sd memory sard
The memory card goes in under the same cover as the battery, on the bottom of the camera. See the illustrations in the "Inserting the battery pack/a memory card (sold separately)" section of the manual. If you need a manual, you may download it and more here.
The camera doesn't come with a memory card, since neither Sony nor anyone else can know what size and speed you want.
Sony Handycam HDR-XR150 - Cannot access data in hard drive. Visible in windows as removable drive E but error message Please insert a disk into drive E: E:31.00 message blinking continuously. Please help....
hi i format my handycam hdr-xr150e(sony) hdd then i see e:31:00 then i insert memory stick and do wht you help(1- Place the memory stick 2- Go to "Home" -> "Manage Media" (or something like that) -> And select the option to change to the memory stick, instead of HD.) now i can record but in top of screen the e:31:00 not removed
3helpful
The door won't close on Sony HDR-HC3
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take?»¿ OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
1helpful
Error code E:31:00, hdr-xr100 camera. will not format, access harddrive, record, etc
The solution is very simple if your camera has a memory stick slot! For those who has any Sony camera with memory stick slot, try this:
3- Go to "Manage Media" again, then to "Format Media", so choose to format the HDD! - Now that you are running the camera from memory stick, you'll not have any problem to format the HD.
At least worked with me! I think it worths the try!
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
