SOURCE: Soundspace 8 - Disc eject / play problem
Hi Kev Frey, Have you checked the mechanism for a broken or loose belting or possibly a broken gear teething. With Regards, Edmund
SOURCE: Does not respond
Thank you Tyrina. It worked. To reset it, when powered on you hold the "stop" buttom and the "power on" button simultaneously until it restes and powers down the system.
SOURCE: DVDR 3350H KEEP READING AND WON'T EJECT DISC
Look under the faceplate where the disc tray ejects and see if there is a small hole. If so, use a straightened paper clip to eject the disc manually by pushing it into the hole about an inch. If that works, then reset the power on the unit and try a nonrecorded type disc to see if the unit works at all.
Other than that, you'll have to take the unit apart to get your disc out.
Hope that helps...
Geno
SOURCE: rca drc8052nb only says ''hello'' on screen, can anyone help?
RCA DRC 8052NB does nothing but displays "HELLO"
Among the voltages available from the power supply is a 3-volt source. The first capacitor after the diode is a 1000 microfarad, 6.3-volt unit. There were no signs of leakage of overheating, but I changed it anyway. Voila! the unit came to life. Hope this helps.
SOURCE: Mini Disc Not Working
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
