The flash drive may need to be REFORMATTED. In some cases, the flash drive is pulled out from the USB port incorrectly. That can lead to a damaged Flash Drive.
Always remove Flash Drives by using the EJECT method.
To format the USB Flash drive, go to the File Explorer (the bottom row of Icons on the computer screen showing a manila folder inside a holder) and locate the USB drive by letter, such as drive B,C,D, etc. One of these letters or higher. Tap the corresponding to the USB drive and an option box comes up. Select "Format" (Quick is ok). Once formatted, the drive is ready to accept data once again. If it cannot be formatted, then the USB DRIVE may have sustained damage to the circuit and no longer can be of service.
The thumb drive you have came already formatted and ready to use. It will read as a DISK because it works the same as a CD or DVD disc. A formatted flash drive is set up at the factory and ready to be used by the new owner. Just copy what you want to move from the computer to the flash drive. When you want to remove data from the flash drive, simply DELETE doing the same as you would on your computer PC or Laptop.
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Insert the flash drive into one of your computer's usb ports.
If this is the first time you are using the flash drive, windows might require to automatically start installing drivers for your flash drive after which you might be required to restart your computer.
Once you are able to see an icon for your flash drive in "my computer" your drive is ready to be used.
Locate the files you wish to copy, select them and press ctrl+c. Then go to "my computer", double click on the flash drive icon and press ctrl+v.
You will see a progress bar indicating the time remaining to complete the copy.
please connect your flash drive to your computer and it wil automatically installs the driver for that flash drive,it shows 'installing driver' and finally it wil come as 'device installed and ready to use'. You can start using the flash drive.
if this doesnt happens follow the below steps,
1.Insert the CD and it automatically starts to install the software.
2. please click on NEXT to install the driver software and click on FINISH to complete the installation.
when you complete the installation you can start using your flash drive.
Just plug your device in USB port of your PC/Laptop, and wait for a miniute, after a while a pop-up will appear in the bottom right corner saying "Device Successfully installed and ready to use".
Now open your "Computer" or "My Computer" you will see a Removable Drive" there, thats your USB Flash Drive, paste there whatever you want and port it to any other Computer.
I Hope you have a clear picture now, Regards, Waqar.
