Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Kingston DataTraveler 1GB while trying to remove the files displays Disk Write Protected error.I couldnt find any switch as per mentioned in the sites. Any solution for it
Azrael SRL
Level 3:
  • Kingston Master 11,800 Answers
  • Posted on Feb 02, 2011
Azrael SRL
Kingston Master
Level 3:
Answers
11800
Questions
0
Helped
2567003
Points
35672
It's in Write Protected mode because the memory chip inside is dying. Try to copy the files and after that junk it.
1helpful
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
6helpful
1helpful
Flash Disk problem
Hi asad_wouria,
Try it on another computer or try to format it. If it continues to give that message then you need to get it replaced at the reseller or with Kingston.
Kingston Tech Support
2answers
My 1gb kingston pen drive is write protected
Try to right click your pen drive then copy and paste it on your My Documents folder. When done, follow these steps:
1. Go to start menu
2. Click Run and type cmd
==A command prompt shows.==
3. Type cd\
4. Type format x:
5. Press Enter key
6. When done type exit
Note: Copy all the files you have transferred on your My Documents folder and paste files again to your pen drive. You can now do whatever you want on your pen drive.
2answers
Newly bought 2GB DataTraveler only show 1GB capacity
Did you read the emanual that is on the Kindston's website for the DataTraveller? When you use the password protection program, it logs you IN to another partition you created when you started it the first time. It logs you off of the  normal drive partition and in to the password protected partition.
Both exist on the same pen drive but can not be accessed at the same time. Try logging off using the same program or if there's such a logoff shortcut anywhere on the pendrive, yo should be back to the normal 2GB partition.
HTH,
Deboo
3helpful
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
I cannot format my kingston datatraveler it says its protected
hello evelymont i found a solution to our problem!!try to download HP USB Disk Storage Format Tool and try to formta the flash stick to fat32 file system!!And after that you're ready to store any file you want unless you put them in a folder first because of the fat32 file system and not saving them on the root for exaple if you want to store an avi file at E: where E: is your kingston usb data traveler save the avi like this e:/name of the folder/avi file, and not in the root e:/avi file!!
that 's it !!congrats for your buy!!
1helpful
3answers
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
