Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
Posted on Jul 11, 2017
I am using Garage Band 08 running on Mac Power PC w/ a 1.4 Ghz processor and 1.38 GB SDRAM and the Lexicon Lambda. I am having a problem recording to a track. . . I keep getting a terrible white noise on each track I try to record a vocal on. GB is set up to recognize the lambda as the audio in/and audio out/ I am recording using a condenser mic, the phantom power on the lambda is on, the track has been set to record mono
5 Related Answers
A
Anonymous
  • Posted on Nov 29, 2007
SOURCE: lexicon lambda
push the monitor button to go mono instead of stereo.
A
Anonymous
  • Posted on Jul 26, 2008
SOURCE: lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
Anonymous
  • Posted on Jun 14, 2009
SOURCE: Lexicon Lambda on Mac
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
Anonymous
  • 54 Answers
  • Posted on Jun 29, 2009
SOURCE: Lexicon Lambda not detected
the usb could be the problem. when you plug it in does your comp make a noise if not it is the usb if it does than the drivers are not in sometimes its a program problem try going to start-mycomputer-(cd/dvd drive right click on it and click explore. find the file labled drivers and install them first than install the program hope this helps.
Alun Cox
  • 2679 Answers
  • Posted on Oct 03, 2009
SOURCE: I change computers, I am trying to run my Lambda /
You'd be better directing your uestion here
http://www.lexicon.com/support/index.asp
Which laptop for 3d animation .use softwares maya,max ,video editing dell's config: Intel® Coreâ„¢ i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA®...
dell\'s config: Intel® Core? i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA® GeForce® GT 420M graphics with Bluetooth (with WIDI) 4GB 1333MHz DDR3 SDRAM (1 x 4G) (operates at 1066MHZ for Core i5 processors) with increased RAM will work fine
Have just purchased lexicon alpha to use on a Mac. Having trouble just getting started. Have hooked up a nice condenser mic into the alpha through the mic input on the rear and cannot get anything on the...
Make sure you have Phantom power turned on on the Lexicon... Oh,oh... it appears that the Alphs may NOT have phantom power which IS a REQUIREMENT for most condenser mics...
The Lexicon Omega does have this but apparently the Aplpha doesn't have it.
That leaves you with the choice of either getting a dynamic mic that doesn't need Phantom, or replacing the Alpha, OR using a preamp ahead of the mic before the Alpha...
Sorry, but those are the only solutions I see for you.
REMEMBER that condenser mics pick up everything and you cannot run them into a PA or they will feedback.
2helpful
2answers
I had a lexicon lambda installed on my old laptop. I lost my installer cd and now can't use my box in my new computer . how do I get the driver ?
Hi here is a link to the drivers for you Lambda.>
http://www.lexiconpro.com/product.php?id=8#downloads
Thank you for using Fixya.com
6helpful
2answers
Install Snow Leopard on a macmini Power-PC ?
If it is a G4 PowerPC processor No
If it is an Intel Processor Yes
My Lambda lexicon will not record in stereo. can any one help
I'm having the same problem with mine. I realize you made this post 1 1/2 years ago, but have you found a solution in the mean time? Thanks!
2answers
Lambda lexicon sound problems: is vista the cause?
No gain
happened to me too, I just fiddled with the phantom power button (wiggled it a little while it was pressed in) and my gain came back *shrug*
2answers
Distortion
It's because when you recording your get sound from Lambda!!! But PC can't reproduce that quality! Try to download driver or update which will allow you to achieve what you want.
Top Lexicon Computers & Internet Experts
goneforever.
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
