It's almost certainly gummed up gas in the carburetor. Get some carb cleaner, and some spray instant start. Drain the gas from the tank and put a small amount of 50/50 carb cleaner and gas in the tank. Remove the air cleaner, open the choke, spray a little instant start into the carb and start it. It may fire just a couple of time. Keep the choke on to try to pull a bit of gas through the carb. You may have to do this a few times. Once you can tell some gas is flowing, open the choke slowly to keep it running until you use up the 50/50 mix. Then try a small amount of straight gas in the tank to be sure it works right, before you refill the tank. Make sure you use a stabilizing additive in any gas that you store for more than a month. good luck, Al K
