Whirlpool LGB6300 Gas Dryer Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My gas dryer starts up heating but after a few mintues it quits heating the drum. I checked the thermo fuse by bypassing it but doesnt mae a difference whats the problem?
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Jun 12, 2011
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10842488
Points
101584
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';;
Dryer runs for 20 minutes then blows cool air, if you let sit for 5 minutes it will blow hot air again but only for a few minutes. I replaced the thermo fuse, and the hi-limit thermostat. I just had the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
I have a Maytag gas dryer, model MDG308DAWW serial 10578801GP. The dryer will start and heat up but after it runs for a short time the burner goes out. I bypassed the thermo limit and the problem still...
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Gas dryer runs but no heat
Those coils are probably getting hot and quitting then after a long time they cool off and work some more then quit again.62a13a2.jpg2720ab1.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
My Kenmore series 80 dryer quit heating. It was intermitent for a few days then quit. I checked the inspection window and didn't see any light. The gas it on and it seems like there is a "click" after I...
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.6aed02c.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
5helpful
2answers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 • Dryers
1helpful
Maytag Gas Dryer LDG7304AAE won't heat
Probably a high limit fuse. Check on the burner shroud for a 2 wire thermos. They should have little resistance. If so replace. If they are open, check for a restricted vent. Remove front panel and clean out area below filter.
Nov 12, 2007 • Dryers
8helpful
5answers
Neptune Dryer
My maytag neptune dryer quit heating, after my wife changed the temp setting on the console from regular, to extra low drying temperature. The heating element reads 10.5 ohms. The thermal cutoff reads 0.02 ohms. The hi-limit thermo reads 0.02 ohms. The power coming into the dryer is 240 volts. What can I check or need to replace.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
