Dell Inspiron 1501 Notebook Logo
Posted on Feb 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I Can't Turn On My Wi-Fi - Dell Inspiron 1501 Notebook
Anonymous
Level 3:
Genius:
  • Master 1,542 Answers
  • Posted on Feb 01, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1542
Questions
5
Helped
286984
Points
4659
Hi
i think it is the blue FN key bottom right and the F2 key above the no 2 key
so press FN+F2 both at the same time
hope this works for you
Turn on my wireless wi fi on my lap top saying my lan in os is off
On many laptops, there is an external switch to turn the wi-fi on/off. This is normally found on the front or sides of the laptop case. It can be easy to turn off the wi-fi accidentally if you grab your laptop a certain way that causes you to press the switch.
On some laptops, you will find the wi-fi on/off switch by raising the laptop screen to expose the keyboard. The switch may often be found by looking at the area above the keyboard. In almost every case, the wi-fi on/off switch will be lit if the wi-fi is on, and unlit if the wi-fi is turned off.
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
How can i connect wi fi to this phone
go to settings, select " Wireless & Networks "
select "Wi-fi" ( It will turn the Wi-fi on )
after the "Wi-fi" is on, then select "Wi-fi settings"
then you will see some Wi-fi networks.
then select the wi-fi networks you know, and depend on the security of the Wi-fi, you sometime have to enter the pass key to get in to the network.
hope it helps.
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Wifi saying unable to scan networks
Hello!
Here are the things you can try for a malfunctioing Wi-Fi on your Galaxy S:
Try turning off your Wi-Fi then turn it on again.
  • Sometimes, this works for me as the Wi-Fi might need a restart so it can try scanning again. You can do so by going to Settings > Wireless and Network > Wi-Fi Settings and ticking the Wi-Fi checkbox.
Turn off your handset then turn it on again.
  • An app that was running on your handset might be messing with your Wi-Fi, so to make all things better, you can restart your handset for a fresh boot. :)
Check if there are actually Wi-Fi networks in your area or the Wi-Fi is too weak.
  • If there aren't any Wi-Fi networks to detect, it can't do anything at all in the first place. Try moving to an area with better Wi-Fi signal.
You can ask me if you have any queries! :) ~azukibean70
1helpful
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
1helpful
Ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
2answers
I dont know how to turn my wi-fi on on this labtop
look around ur laptop, there should be a button key or a switch 2 turn it on. if look on the bottom right on ur taskbar, there might be an icon for ur connections e.g. bluetooth, wlan, wi-fi etc. see if u can switch it on from there. if u still can't do it take ur laptop 2 a pc world center and they might be able to help u. i hope dis helped =)
1helpful
2answers
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
