Motorola Mobility H300 Wireless Headset Logo
Posted on Feb 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you set the H300 to pairing mode - Motorola Mobility H300 Wireless Headset
Anonymous
Level 2:
  • Expert 91 Answers
  • Posted on Feb 22, 2011
Anonymous
Expert
Level 2:
Answers
91
Questions
0
Helped
40999
Points
263
Startingwith the power off push and hold the call button while the head set turns on....then continue holding the call button until the light turns blue that has enabled the pairing mode now the pin code for all h300 model bluetooth device is 0000..i hope this helps
1helpful
Pairing code for ohh-h300
THe factory code to pair is usually a simple code like 0000 or 9999 or 1234. Try these simple codes to see if it will work.
Morotola H300 with Blackberry Device
re-pair and add to trusted devices be sure to use 0000 for passkey
USER GUIDE
1helpful
Not paired, Motorola Blue tooth H300 to iPhone 3G S
hi
when the bluetooth id discovered it has to be registered with the default code of 0000 over the handset to be paired
hope this helped
cheers
Trying to pair a h350
you can name the headset anything but the passcode is 0000
Need a pass key for a motorola h300 in order to pair it with a samsung sphm 540
the pass key is 0000
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
When your headset is successfully paired
Pass key
pass key 0000
for more clear instructions go here
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
repeat step 1.
PAIR
Your Phone
device.
from 0000.
YOUR HEADSET
2helpful
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
2helpful
H350
repeat step 1.
PAIR
Your Phone
device.
from 0000.
YOUR HEADSET
1helpful
3answers
Pairing bluetooth with new phone
You have to hold the on button until it is a solid blue light not flashing 5 or 6 seconds then it is ready to be paired.
3answers
Passcode
Try the passcode "0000." That's "zero zero zero zero."
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
