F 21 means slow drain if you can here the pump that means something pluging it. remove lower kick plate . the pump will be there remove cleanout counter clockwise turn .put back together.. hope this helps...good luck
Unscrew 3 T20 star bit screws attaching kick plate to front of washer.Unscrew (counter clockwise) filter to pump assembly & remove any debris (missing socks & whatnot). Re-assemble.Run clean cycle with cleaning tablet. Resume normal usage.
thank you, that's exactly what we're doing now. Found the filter clogged with pet hair, a ponytail holder and gunk. Smelled absolutely disgusting, so we ran the filter under hot water and reassembled. Now running through with Affresh. If this works I think it will take care of not only my F21 error code but the contact "suds" message. I will be having my husband clean out this filter often from this point on.
What does f 17 mean
The fabric softner empties with the laundry detergent. is this normal?
