My brand new motorola H620 is not charging. i folowed all the instructions and noticed the red led flash. Even after charging it all night, the LED was still blinking red
get the new charger; and consider returning to store or manufacturer.
if you have the black charger, throw it out
you need the green/two-tone charger for ryobi one 18v
Your radio needs to be turned off when on the charger, and be certain you are using a rechargeable Motorola battery. The charger will not charge AAA batteries or rechargeable style AAA batteries. If the light does not illuminate on your charger, try the radio in a different charger and see if it does. This will tell you if it is the radio or the charger. One further note, you should clean your charge contacts with a pencil eraser to insure they are making good connection.
if the flashes are rapid, normally it means that the connection was successful. A quick google search for motorola h620 should bring up the users manual in pdf format with an explaination of all the light combinations
Dell Inspiron 1525 PC Notebook
Hi,\r\nAt my dell 1525 the battery...
Answer
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
Charging LED Red LED is on = Being charged Red LED is blinking = Charging error Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error. - The battery is not properly inserted - The terminals of battery are dirty or damaged If the battery is inserted properly and the charge indicator continues to blink, contact the nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Did you find a solution? I have the same problem
Hello need help with this please
