You need to look at your image storage settings. Press "Menu", "up/down" and "OK" to choose "Image Storage"; is it set to "auto" or "internal"?
If it's set to "Auto" then there's some reason that it's not recognising your memory card. You should format it. Press "Menu", "up/down" and "OK" to choose "Format" and then select the memory card.
If it's set to "Internal" then you need to set it to "Auto". Then it will use the memory card if it's inserted. (Take the card out to access the photos in Internal Memory.)
