Fieldvision 114mm Reflector (114 x 114mm) Telescope Logo
Anonymous Posted on Feb 01, 2011
How do I fix the upside down image - Fieldvision 114mm Reflector (114 x 114mm) Telescope
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Feb 01, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
218858
Points
3782
Astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear.
It is possible to fit an erecting prism or eyepiece to most astronomical telescopes, and some of them come with one, but if you want a telescope primarily for terrestrial use, you are much better off buying what is called a "spotting scope".
If the telescope has a standard 1.25 inch diameter eyepiece, then an erecting eyepiece may be found on Amazon or eBay. An erecting prism or diagonal of the type that bends the light through 90 degrees is not right for a reflecting scope. These are used on refractors.
  • heartsurgeon Jun 06, 2011
    this was really helpful thanks
Projector screen upside down
Check the settings for image alignment. You may have to look for the vertical and horizontal image settings.
This could be because the default is table mount and you may have mounted on ceiling.
1helpful
Why are my images upside down, how do i fix it? was working fine earilier
All astronomical telescopes show upside down images, you must add extra glass to erect the image which will dim the images of deep sky objects in the eyepiece.
You can buy an "erecting" prism for terrestrial viewing.
Here:
http://www.agenaastro.com/GSO-1-25-45-deg-Erect-Image-Telescope-Diagonal-p/odia-gs-pd45.htm
2answers
Image Upside-down
i think you should enter the setting mode and check their for image flip settings or something.
19helpful
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
How do I correct an upside-down image?
Normal 0 Try this, while the computer is running, unplug the camera from the USB Port , wait a few seconds and then plug it back in. I have fixed several cmaeras that were upside down that had the same problem by doing this.
Worth a try.
Hope this helps. Bud
Upside down image
I fixed it by finding a site that posted a solution without misleading and charging for the info.
Can I get an upright image with camera mounted upside down
Flip the image in post. Most editing programs have a vertical flip effect that will fix everything
2answers
UP SIDE DOWN IMAGE PROBLEM
Normal 0 Try this, while the computer is running and the picture is upside down, unplug the camera from the USB Port , wait a few seconds and then plug it back in. I have fixed several that had the same problem by doing this.
Worth a try.
Finderscope image upside down & not focused if viewing past 100 yards
The upside down image is normal for astronomical telescopes. The finder usually is a fixed focus, but it can be altered for various eye types, by rotating the objective lens for focus - the cell should move in or out on fine threads.
Top Fieldvision Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Fieldvision Optic Expert? Answer questions, earn points and help others
