SOURCE: For Atheros PCIE Ethernet Controller... check
You didn't list your PC model or make, but it appears that you have enabled the network card to boot from it's rom chip. Turn that option off in your software or pcie Bios control.
system is trying to boot to a network, this is most likely due to the hard disk drive not being detected, or the windows operating system is missing.
First reset the BIOS defaults, see if the system detects the HDD in the bios and will now boot.
Run diagnostics on the hard disk drive, which I suspect it will fail.
If diags on the drive pass, they try reinstalling Windows. But I expect you'll be replacing the drive.
SOURCE: Upon startup before anything else
This means you should install an Operating System.
If your notebook doesn't have a dvd drive you can install the Operating System with an external drive (dvd, USB flash drive or hard drive). and press F12 when it starts to select the booting device.
Follow the link below to find out how to create a USB flash drive bootable (also works on hard drives):
http://forum.bstdownload.com/how/55-how-create-bootable-usb-stick-when-using-windows-vista-windows-7-a.html
