SOURCE: Can NEC Telephones, ( in aprticular NEC 1000 24
VoIP in this case is probably the way you'e going to have outside telephone numbers delivered to your premise. They usually come with boxes that you would plug a regular phone into and get dial tone, or in this case, you'll wire each Analog Terminal Adapter, ATA jack to the line side of a trunk in the DS-1000.
Since the DS has 3 lines per jack, you're going to either need an adapter that breaks out L1 L2 and L3 or someone who can wire a 6-pin jack and use a 6-wire modular to modular cord to break out your individual lines to the ATA's.
It's a fairly quick job if you know how to do it.
Carl
SOURCE: I have a NEC Dterm Series I phone. I inadvertantly
If you have a key system try dialing 42 or 69, If you have a pbx try dialing #8
SOURCE: how to trfr call..??bcoz my NEC IP2AP 924m ksu cannot trfr
To transfer a call, do not press hold, but press Transfer. You will hear a studdered dial tone. Dial the number to which you are transferring. When you hang up, the call is transferred.
