Question about Jabra Stone Bluetooth Headset
Jabra stone will not turn on?? - Jabra Stone Bluetooth Headset
  • 100 Answers
Not fullycharge batterry... you need to recharge atleast 10hours in you laptop...
thank you...
Posted on Feb 01, 2011
SOURCE:
Dont no how to pair order on ebay no hand book
this is for the stone 1
http://www.jabra.com/sites/mobile/na-us/support/pages/pairingguide.aspx
this is for the stone 2
what phone are you trying to pair with the bluetooth headset?
the default codes for jabra headsets are 0000
Mar 01, 2011 | Jabra Stone Bluetooth Headset
Hello my jabra wont light up when it is fullcharge? can you help me?
The headset light turns off when it is at full charge. If it is not charged yet it will be illuminated red.
Found this in the online manual:
http://img5.jabra.com/sites/Jabra/GNimages/Products/Stone_Manual_EN_NA_8404.pdf
Feb 28, 2011 | Jabra Stone Bluetooth Headset
I am having trouble pairing the Jabra Stone with my iPhone 3gs. I have held down the stone button multiple times and nothing happens. Also i have turned it on and off multiple times, but it just wont...
Hi, Look for "Add new device". Hit OK.
the phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
I've reviewed Bluetooth headsets before, and I would have to say that the Jabra STONE is one of the sleekest looking. Its shape is designed with minimalist simplicity, with a shape made for either the left or the right ear.
This shape goes onto a charger that is perfectly made to accept the Jabra STONE like a puzzle piece. This charger is probably what sets the STONE apart from most Bluetooth headsets, as it can charge the headset as the user goes. A green indicator means that it has enough charge for one full time or more. The red indicator means that it needs to be charged.
The STONE can be charged with an AC cord or USB connection. Once it is charged, there is a pairing indicator that made it simple to sync with my mobile phone. It has about 12 days (288 hours) of standby time and 8 hours of talk time.
I found that pairing the STONE with my phone was quite simple. In a matter of seconds, it was connected to my phone and I was making my first phone call on it.
The sound for the STONE is pretty good, with dual microphones and their trademarked Noise Blackout Extreme and crystal clear sound and voice with DSP.
One of the big features that I found is the touch sensitive volume control. In other words, there is no buttons for controlling the volume. I welcomed that, and most volume controls on Bluetooth headsets are really, really tiny buttons.
Other features include the ability to connect to two devices at a time, and it can stream music from an A2DP enabled mobile phone.
This is the problem that I had with the STONE. I found that there isn't really a "standby" indicator. I found that using it was a hit or miss situation. If I just pulled it out of the charger, it would sync with mobile it would work. When my phone rang later, and the headset was out of the stone cradle, and hitting the "connect" button didn't help. In short, I had to answer my phone. The Jabra STONE failed me, but I remember having similar awkward experiences when I first used other Bluetooth headsets.
The Jabra STONE comes with the headset, charger, 2 Eargels, a belt clip, AC charger, and a USB charger. You should be able to get it on Amazon for about $90 as the price to this writing.
Feb 24, 2011 | Jabra Stone Bluetooth Headset
Hi iam trying to connect my jabra stone but my cell phone it asking the passkey
The manual notes that if asked for a pass-key you should use 0000. Give that a try. Hope this helps!
Feb 09, 2011 | Jabra Stone Bluetooth Headset
I have tried everything in the manual to pair it with my iphone 3GS 4.1 but it's still not pairing. The iphone is looking and looking but doesn't find the device. Even turning the jabra stone of and then...
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 15, 2010 | Jabra Stone Bluetooth Headset
Even after charging the jabra stone does not come on nor pair
I am having same problem. Stone seems to be charging, but headset will no longer operate. Have used successfully for 5 months.
Sep 15, 2010 | Jabra Stone Bluetooth Headset
How do i pair the jabra stone with the iphone 4? seems like i cant pick up anything from it when its in pairing mode.
Just did it myself. Ensure the iPhone is discoverable and searching.
Switch the Stone off by squeezing down the control surface until it bliddle-omps.
Put it into pair mode by squeezing the thang again until the bluetooth light flashes. Keep squeezing.
Watch the iPhone - it will pair automatically - no password required.
Sep 03, 2010 | Jabra Stone Bluetooth Headset
Jabra Stone Bluetooth Headset Logo
422 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
