Refrigerators Logo
Posted on Jul 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water runs without pushing dispenser switch
I have a kenmore side by side
the water dispenser just started dripping and turn into a full steam of water
Anonymous
Level 3:
  • Master 447 Answers
  • Posted on Jul 20, 2008
Anonymous
Master
Level 3:
Answers
447
Questions
5
Helped
355748
Points
1420
Water inlet valve is bad ----replace it
My wife noticed our side-by-side GE Turbo Cool water dispenser was dripping water so a quick look in freezer showed a huge ice buildup in the drip tray that had frozen back into the spout. We emptied both...
let see if I understood correct me if i'm wrong! When you close the freezer door water star running from the dispenser? If so you water valve solenoid is staying in the open position just replace it.
Water dispenser dripping...
May be you can. Just check if your drip tank is full and if it is forcing the overflow. If it is not that, check the opening to the drip tank and see if it is closed with ice or something similar. If it is not that bath, then i'm sorry but you have to turn off the water supply line.
Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Water dispenser in door front is leaking.
The water inlet solenoid is bad. Unplug frige. Follow inlet line to back of frige to part. Replace part.
Just changed pur water filter on kenmore elite side by side and now water dispenser drips
this is normal. trapped air from the new filter will cause it to drip until all air has cleared. if you will run about a gallon of water thru the dispenser it should help if not stop the dripping all together. thanks peyton
Water dispenser
I HAVE THE SAME PROBLEM WITH THE WATER CONSTANTLY DRIPPING FROM THE DISPENSER, I REPLACED THE HOSE AND THAT DIDN'T DO IT. ANY SOLUTIONS?
Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Water dispenses without pushing lever
There is a solinoid valve that opens when you push the switch in. It has apparently failed and is leaking. Sometimes taking it apart and cleaning it will fix the problem.
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
