The installation software for the HP Deskjet F2410 printer can be found at the following site,
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
When you arrive at the site, input your printer's model number (f2410), into the block marked,
" for product" and click the arrow, you will then be guided to the drivers for your printer.
You should be happy with the results.
Access the manufacturer's web-site: http://support.hp.com
Enter 'F2410' and do a search.
Pick the device-drivers for your Operating System.
Download.
Install.
Print.
SOURCE: my printer hp deskjet f2410
1.Check if there is low ink level in cartridge
2. Check if there is any piece of paper stuck inside
3. Unplug the power cord while its ON , Press and hold OK and CANCEL at the same time, while holding them plug in the power cable and then release the buttons.
It should fix the problem
Unplug the power cord from the back of the printer while its ON
now Press and Hold
Ok and Cancel button at the same time
While holding them plug in the power cord
Once the printer turns on release the buttons
You will see the Reset message on screen of your printer and in the process it will align the cartridges
