Motorola MC75 Logo
Anonymous Posted on Feb 01, 2011
How to factory default Mc75 device - Motorola MC75
  • Anonymous Mar 31, 2014
    Factory reset
  • Sam DeGonia Jun 29, 2019
    doesn't work-package not found error
Anup Kumar
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Nov 07, 2012
Anup Kumar
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
26010
Points
20
Instructions:
Before performing a factory reset or clean boot the mobile handheld device, please back up all your important files/data from the mobile. Factory reset or clean boot may remove the personal files and folders from the device.
Download the files, 75XXw60HenCB0100.zip and 75XXw60HenCBA0100.zip on the PC using the below mentioned web link.
https://docs.symbol.com/KanisaPlatform/Publishing/666/12319_f.html
Save the files on any location on the PC. Better to save on the desktop screen for easy navigation.
Right click on the saved zip files and extract the zip files to a known location on the PC.
Copy and paste the extracted files to either the root of an SD Card (and place the SD Card in your device) OR the TEMP folder of the Motorola MC75 mobile handheld device.
Note: When the zip files are extracted, we will get 4 or 5 files. One of the file is StartUpdLdr.exe
75XXCLEANBOOT.ZIP
This file is intended for use when a CLEAN BOOT of an MC75XX WM 6.0 device is required. Unzip the contents of this device to either the root of an SD Card (and place the SD Card in your device) OR the TEMP folder. Then follow the UPDATE LOADER boot instructions below.
75XXCLEANBOOTANDBLANK.ZIP
This file is intended for use when both a blank Application Folder and a CLEAN BOOT of an MC75XX WM 6.0 device is required. Unzip the contents of this device to either the root of an SD Card (and place the SD Card in your device) OR the TEMP folder. Then follow the UPDATE LOADER boot instructions below.
Note: Although the zip file references only Windows Mobile 6.0, however these packages are approved for use on all version of Windows Mobile 6.x.
Steps to accomplish the factory reset of Motorola MC75 mobile handheld device
There are two methods to perform an Update Loader Boot/ Clean boot on MC75:
Method 1:
Perform a cold boot:
To perform a cold boot on the Motorola MC75 handheld device simultaneously press the Power button and the 1 and 9 keys.
Immediately, as soon as the device starts to boot (before the splash screen is visible), hold the upper right hand trigger key.
The screen should display a message with the words "Update Warning" at the top of the screen.
Place the device on A/C power either by placing it in a cradle or a CAM. The update will automatically start after AC power is detected.
The device will invoke an Update Loader boot, which will cause the PKGS.LST file deposited on the device to be processed. Leave the device on A/C power during the Update Loader process.
Method 2:
Navigate to the root of an SD Card OR the TEMP folder of the Motorola MC75 mobile handheld device.
Tap 'StartUpdLdr.exe'
After 20 seconds or so, the device will perform an Update Loader boot which will cause the PKGS.LST file deposited on the device to be processed. Leave the device on A/C power during the Update Loader process
When the device has completed the process it will return to the Windows Mobile ""Tap the screen to set up your Windows Mobile-based device" screen. At this point, if you used an SD card, please remove it from the device. If you placed the files in the TEMP folder, they will be automatically erased by the CLEAN BOOT process.
  • Achim Weber
    Achim Weber Dec 20, 2014
    I Have the same problem - can you help me - Motorola MC7596 ā€“ PYCSUZWG9WR ā€“ Windows 6.1 German
JDTec
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Motorola Master 4,338 Answers
  • Posted on Feb 01, 2011
JDTec
Motorola Master
Level 3:
Answers
4338
Questions
0
Helped
2126979
Points
14653
Resetting the MC75
There are two reset functions, warm boot and cold boot. A warm boot restarts the MC75 by closing all running
programs. A cold boot also restarts the MC75, and also resets the clock. Data saved in flash memory or a memory
card is not lost.
If the MC75 is not functioning properly, perform a warm boot first. If the MC75 still does not respond, perform a cold
boot.
Performing a Warm Boot
Hold down the Power button for approximately five seconds. As soon as the MC75 starts to boot release the
Power button.
Performing a Cold Boot
To perform a cold boot simultaneously press the Power button and the 1 and 9 keys.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
  • DataDennis Feb 04, 2011
    Can anyone explain how to update the PRL forthe device?
  • JDTec
    JDTec Feb 04, 2011
    Software downloads are available to Motorola customers as part of their Enterprise Mobility Services agreement. Enterprise Mobility Services agreements provide technical telephone support, rights to download entitled software releases, including patches and updates, and supporting documentation. Patches and fixes are also available to those customers with a valid software warranty. :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
    To request access to this software please complete the Request Download form. Please note you must first register and login to Support Central
    http://support.symbol.com/support/mysupp...
Factory reset motorola mc75
It is best to contact Motorola Solutions. portal motorolasolutions com
Mark
Motorola Mobility Support
2helpful
No signal on motorola mc75 scanner when in metal building
Information regarding metal building may well be correct as metal buildings can act as a farraday cage blocking radio signals.
Soft reset MC75 through code
Go to settings on your phone then it will say security reset four sections down ,click it then your phone will reset.
Where do i go on my phone motorola 75 to reset
Download "clean boot" files from support.symbol.com and run the files as stated in .txt file. This resets the device to factory defaults.
2helpful
How to hard reset the motorola MC75
If you want you all default setting of phone n make its setting as it is a new phone then u do the following...
Go to setting
then to restore factory setting
then enter you phones code n let the phone restart...
you have done...
I installed Datawedge.exe in my MC75 device. How can I read barcode using this software?
We have set up many of these device with Datawedge. The configuration depends on what type of barcodes you want to read. Contact me www.datexcorp.com and we can walk you through it at no charge
2answers
Hi i have motorola mc75 and i want to re install windows mobile 6.1 on it . how can plz?
in order for you to download teh software you will need a motorola svc agreement on your device, if you do then you go to support.symbol.com, if you have an issue finding it please let me know and we will walk you through this
[email protected]
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
