No -there are no drivers to install. I would even suggest
not to use any CD that came with the router (in your case the so-called "Quick Router Setup Wizard CD".
It is always better to configure the router by hand, otherwise you have to look forever if you have to troubleshoot.
If you connect your Mac to your DSL- or cable modem, can you access the internet?
If yes, then you have to configure your router. If not, then there is a problem with your internet connection in general and you have to contact your ISP.
Connect to your router (via cable) and check that the SSID is broadcasted and your wireless security is turned off, until you can connect wireless to your router. Look at the manual page 22 (if you don't have a manual, you can get it
here.)
- Enable Wireless: ON
- SSID: whatever you like
- 802.11 Mode: MIXED (unless your MAC is 802.11n capable - you can change that later)
- Channel Width: AUTO
- Visibility Status: VISIBLE
Then follow the Wireless Security Setup Wizard (ideally do it manually, but this works too). You find a description up from page 64 in your manual. For now, select no wireless security and complete the wizard. Don't forget to save your settings.
Now you should be able to connect to your routerwireless from your Mac.
After this is accomplished, go back to the wireless security setup and secure your network with WPA2 Authentication.
If you have any more questions or get stuck at one point, just come back here and leave a comment - I'm happy to help.
AXAXA
