SOURCE: i lost my installation cd of touchmate webcam, where can i download easier installer here?
try this site
http://mrdriver.com/device.php?id=39044
lists driver for lifecam vx 1000
wil u pls send me a pc suit .......
model no:TM-CAM110
SOURCE: Microsoft LifeCam VX-6000 won't work with AIM
Try installing Skype. Its free and works best too chat with Family and Friends. After installing use info below.
Normal
0
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to broadcast
on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
The camera and audio should function properly. Your friends and Family will now see and
talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up
as follows:
C. Windows Live
Messenger:
NOTE: You audio and
video shoud work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this helps. Bud
SOURCE: does skype work with Microsoft LifeCam VX-6000?
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
SOURCE: microsoft-lifecam-vx-6000-windows-2003-driver
I had the same problem on my 2003 server, use this link to load software:
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
