Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer stops when it goes past the was cycle not rinsing
I have a whirlpool ultimate care II washer and it washes to the point of load size small, it will not follow to the rinse cycle. I have a washer fill of water and clothes. Really not sure where to start ont his.
  • sammiegirl Jul 22, 2008
    Mine does the same thing. Just stops with a washer full of water at the end of the 6 min wash. Also stops on the rinse/spin cycle sometimes. Could it be the timer?
I don't know if it will work for everyone. But I took my back off of my contol. You know the knob that goes around. There are two little srews in the back, up top but there are also two hidden screws that are down inside the edge. I found that I had a control unplug inside. I also bent my stopper that goes down in where the lid hit the controll to make it spend. It know works like a brand new one. Good Luck
Posted on Jul 27, 2008
Check the door safety switch when you lower the lid. There is two screws on the right side of washer tub opening. They screw into the switch housing which is made of plastic. On my machine the housing cracked and the tab on the door could not push the switch all the way down.
Posted on Jul 24, 2008
2 Suggested Answers
SOURCE:
mikedurland
  • 481 Answers
SOURCE: Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Posted on Jun 28, 2008
My Whirlpool washer (Ultimate Care II) stops at
This is probally the lid switch. You can check this by checking for continuity. You should have none with switch open and some continuity when switch is closed if yours has continuity when opened you will need to replace. There is a video at www.appliancehelponline.com/servicemanual.html that can walk you thru the replacement.
Mar 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Washing Machine Rinse cycle not workin
Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Let me know if you need further assistance. I hope this helps you.
Jun 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Shuts off in between rinse and spin cycle
check the lid switch. if it's loose, worn or broken washer won't drain/spin. try pushing down on the lid when it's stopped. switch is either on the right side visible with a small hole that a plastic activator on the lid itself or on some activated by the left hand rear hinge under the top and need the hinge tightened only..
May 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
