The F50 code for the Whirlpool Cabrio is most commonly a Motor Control Board failure.
Motor Stalled
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
? Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
? If basket turns freely, see TEST #3, page 4 of the Diagnostics and Repair manual.
The Diagnostics and Repair manual can be downloaded as a PDF document file here:
http://www.mediafire.com/?np4yufblj33c0xm
DIAGNOSTIC TESTS
There are three diagnostic test modes available: Automatic, Manual and Console. These tests allow the factory or service personnel to test and verify all inputs to the machine/motor control. You may want to allow the automatic test cycle to complete prior to going into specific troubleshooting tests.
ACTIVATION OF AUTOMATIC DIAGNOSTIC TEST MODE
? If there are no saved fault codes, all indicators on the console will momentarily turn off, then
turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
DIAGNOSTIC: Automatic
Performs a five-minute automatic test with water functions to check major washer functions (door can be open). Press the same button used in step 2 above to advance through automatic test steps.
NOTE: Basket must be floating in order to agitate.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
