Janome Memorycraft 9700 Computerized Sewing Machine Logo
Posted on Feb 01, 2011
I downloaded some design off of the internet on to my computer and then onto my pc card. Computer says they are on the card but when I put in machine the designs are not there.
akime
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Aug 14, 2011
akime
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
1098
Points
There are several possible answers. On the pc card, you must have a folder called EmbF5. The sewing machine will put two directories onto you pc card when it formats it--Ord#5 and EmbF5. The embroidery designs are stored in EmbF5 and series of sewing stiches that you want to save are stored on Ord#5.
I have had the same problem. I have two pc cards which I formatted on the computer and placed the two file folders EmbF5 and Ord#5 on the disks myself. I cannot get the machine to read these. I suspect that the machine wants to format them itself; however, the literature on the subject suggests that you can format the cards on your computer. (You must use the FAT option.) Also, I cannot get the machine to reformat them, so maybe they are defective.
If you get a new disk, put it into your machine. It will format it for you and place those two folders on it. If it does not format it, go to the set option on the menu, go to the third 'page' and you will find the format ATA card.
Also, be sure that your card is 512 MB or smaller.
2helpful
I can get the designs from memory stick to the sewing machine what am I doing wrong
not sure what sewing machine your using but maybe this will help.
Getting That Embroidery Design To Your Janome Posted on August 21, 2010 by b.gottier
It never fails. When I sell a Janome embroidery machine, the customer always comes back and says they can't get their designs to their machine with their USB stick or CF card. Is something wrong with the USB stick or CF card? Is something wrong with the machine? No and no are always the answers to these questions. The real problem is that the customer is not placing the design files into the correct folder on the USB stick or CF card. I can't blame them for not knowing this, because the owner's manuals don't make it very clear. Unless the designs are placed into the right folder, the machine will not see that they are there, and you won't be able to use them.
Destination Folders For Designs Machine Destination Folder Media Type MB-4 EMBF folder in EMB folder USB stick & CF card MC11000 EMBF folder in EMB folder USB stick & CF card MC10001 9 folders ( EMBF5 thru EMBF16 ) CF card MC10000 EMB_FILE folder CF card MC9900 EMBF folder in EMB folder USB stick MC9700 EMBF5 folder CF card MC9500 EMBF5 folder CF card MC350E MyDesign folder in EMBF5 folder USB stick MC300E v1 EMBF5 folder CF Card MC300E v2 MyDesign folder in EMBF5 folder CF Card MC200E EMBF folder in EMB folder USB stick This tutorial is going to show you how to get your designs into the right folder on your USB stick or CF card. The designs will then be recognized by your embroidery machine, and you will spend more time embroidering and less time wondering what is wrong.
Preparing Your Storage Device
First, before doing anything else, stick your USB stick or CF card into your embroidery machine, then turn on the machine. By doing this, your machine will create a necessary folder system on the stick/card, into which you will place your designs. Normally you will see a message on the screen of your machine that tells you not to take the USB stick or CF card out for a little while. Once this message goes away, turn off the embroidery machine, and remove the card/stick.
Finding Your Storage Device On Your Computer
Now plug your USB stick into your computer, or insert your CF card into the CF card reader of your computer. We now want to open a new window and navigate through the computer to find the USB stick or CF card. I would normally access the stick/card through "My Computer", but you may also use Windows Explorer. If you are lost at this point, you may require a lesson or two in basic computer usage, but this is beyond the scope of this blog post.
When you have successfully navigated to the USB stick or CF card on your computer, you will notice the folders that your embroidery machine made. The destination folder for your designs is shown in fig.1. For example, if you have an MC11000 or MC11000SE, you will be looking for an folder named EMBF that is inside a folder named EMB.
Once you have the destination folder open, minimize that window by clicking the _ button in the upper right corner of the window. We will come back to it later.
Finding Your Designs On Your Computer
Open up another window, and this time navigate through your computer to find the designs you want to transfer. Sometimes the designs are on CDs, and sometimes the designs are downloaded from the internet. You will need to find your designs by navigating through your computer. I can't tell you where they are, because you were the one that put them there. I use Windows Explorer to browse through my computer, but you may also access your designs through "My Computer". Once you have found the location of your designs, typically files with a .jef file extension, proceed to the next step.
Copying Your Designs To Your Storage Device
Copy the design(s) you want to put on your stick/card by right clicking on them and clicking "copy".
To select more than one design to copy at a time, just hold down the CTRL key on your keyboard and click multiple designs. With all the designs highlighted, right click on any part of the highlighted area and click "copy". Next, maximize the window of your destination folder, right click inside it, and click "paste". You will now see the design(s) you wanted to transfer in the destination window.
You can now pull the USB stick/CF card out of your computer, and insert it into your embroidery machine for stitch out. Your machine will recognize that the designs exist, because you put it in the right folder!
If you have followed my instructions, you should be ready to embroider
1helpful
I have just purchased an old Janome Memory Craft 10001 embroidery machine and need the drivers in order to be able to connect it to my pc via usb cable.
You can go the the Janome web site to find drivers for your computer. When you save designs to the memory card you must save them in a folder (emb, i think}.Put a blank card in the machine while the machine is off anf=d then turn the machine on,,,It will make the folder for you.
Good Luck
Dongle won't work
did you try the dongle in another port... yes if you can find the patch you can load it onto a flash drive or sd card and then upload it over to the new pc
I can not get my designs i downloaded off line on to my baby lock
You have to have an Amazing Box or similar device and a blank memory card. You hook the Amazing Box up to your computer, put the memory card in it, and transfer the designs onto the card that way. Then you use the card in your machine like any other embroidery card.
2answers
Start up..Babylock BMP6
Not if you just want to get the patterns off the internet, etc., you cannot, or at least with my older version, make your own designs. You need to download the program to your computer. Its pretty simple if you get on the internet and download the designs put your palette on your computer, go to the designs, with a blank card, and load the patterns. Hope this makes sense.
3helpful
4answers
Brother PED-Basic Driver?
Dear Kooks57, you have not deleted your designs, the program, card reader and card you purchased are for downloading designs from the internet or a computer. You will find free designs all over the internet including Brothers site. To use the reader you will download your designs from the internet or another card with designs on it and put them in a specific folder on your computer, then you can tell the Basic program to seach that folder and move the designs you want to the card in the reader. Once the designs have been moved to the card you can use it in your machine. Hope this helps if you need more help please follow the user instructions step by step and it should get you where you want to go, See page 8 in the manual.
Gale
1helpful
2answers
Downloads to iMac
Google "BriTon Leap" for solutions for using your iMac. They have programs called Embrilliance, which works with iMac
Connecting to a computer
Are you asking how to connect the Brother PE-400D sewing machine?  You have "how to connect the '4000D' to a computer and what risk if any".  Which machine are you asking about - these are two different sewing machines.  If you are inquiring about the Brother PE 400-D, then your answer is... this machine is NOT capable of being connected to a computer.  However, if you wish to purchase or download embroidery designs from the internet, you may look into purchasing the Brother PE Basic. This allows you to download embroidery designs from the internet to your computer hard drive and then load them on to a Brother memory card.  The Brother memory card can then be slipped into the proper slot for the memory card on the sewing machine.  You will need to purchase embroider designs that are in the PES format for you Brother machine to read it.  Hope this helps!
PC card adapter
I too have just purchased a new machine and had same problem.  You have to put the card in your sewing machine first to format it.  My machine is a Janome 10001 but think it is the same concept.  When I save a design from the internet to the card I have to drag the design into one of the Emb folders which will show up on your card after it is formatted.  Then after saving the design I can go back to the Emb folder that I saved it in and it will show up on the machine.  Hope this helps.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
