SOURCE: Optiarc DVD RW AD-7561A This device cannot start. (Code 10)
I beleive that this code is being displayed under the Device Status in the Properties window of the DVD Drive in Device Manager.
If it is so, you need to do some modifications with the Registry to resolve the issue and I am sure that the issue will be resolved with this.
However, since you had not specified the Operating System which is installed in the Notebook is Vista or XP.
However, I am providing the links which includes the steps for both Vista and XP to edit the registry to resolve the issue with Error Code 10 with the DVD Drive in your Notebook.
Removing Upper and Lower Filter in XP :
http://support.microsoft.com/kb/314060
You need to perform the steps listed under Advanced Troubleshooting to delete the Upper and Lower filters.
Removing Upper and Lower Filter in Vista :
http://support.microsoft.com/kb/929461/en-us
You need to perform the steps listed under Resolution in the link above.
You may not find both the Upper and Lower filters according to the instructions links provided above.
Delete the ones among the Upper filter or Lower filter or both which you find in the locations mentioned.
This should solve the issue...
SOURCE: optiarc dvd rw ad-7561a ata driver
weird. Try using Windows System Restore to revert back to before installing dameon tools. You can try installing it again but I would re-download just to be safe. It it happens again you might want to try alcohol 120% instead.
SOURCE: windows is unable to identify cd-dvd drive
Kindly let me know the name of the device, do that I can give you the link to the device driver.
Hope it helps.
SOURCE: dvd rom is not readable or not showne in my computer
I have had the same problem and error code.
It started as an intermitant fault and then just stopped working.
You can try going into device manager and uninstalling the dvd drive, it will automatically reinstall.
I had to buy a replacement off ebay for about £20, they want about £100 for a new 1
control panel admistrive tools,computer management,device manager scroll cd/dvd rom drives right click you can update driver disable or uninstall select properties from there you can troubleshoot or select driver you can update roll back driver uninstall if at any time you see a yellow question mark? you need to install a driver
hope this helps
