One Touch Jitterbug One-Touch Cellular Phone Logo
Posted on Jan 31, 2011
How do you turn up the ringer volume on the Jitterbug phone. It's currently set on vibrate & I don't know how the volume got turned that far down.
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 33 Answers
  • Posted on May 18, 2011
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
33
Questions
0
Helped
45907
Points
41
First, make sure your Jitterbug phone is turned on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the ringer volume level. The ringer volume ranges from Vibrate to Max.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
  • David Simonson Mar 25, 2016
    As usual this is worthless info wanted to find how to turn on ringtones on a jitterbug but after an hour reading all repairs for this phone found nothing other than company advertisements disguised as reviews hey if your not going to put out real useful info then their must be something seriously wrong with your phone
Jitterbug flip won't ring. I've checked the volume and it's set at maximum What is the Jingle, I've tried both ways, no help. Exasperated, donna
Page 30 of manual at the link shown suggests a way to silence the Jitterbug.
http://www.specsserver.com/CACHE/FREOWQFWSXOG.PDF
Quoting from Page 30:
To adjust the ringer volume:
1.
Be sure the phone is open and on.
2.
Press the
Up/Down
volume button
on the outside of the phone below the
display window. Press each time you want
to advance to the next choice.
These choices will appear on the screen:
- Ringer Volume Ring Max
- Ringer Volume High
- Ringer Volume Med
- Ringer Volume Low
- Ringer Volume Silent
3.
When you're satisfied with the setting,
release the volume button.
Your Jitterbug may ring and vibrate
to alert you to incoming calls. The
ringer and keypad can be silenced
by pressing the volume button
Down
until
"Silent"
appears on the screen. Your
Jitterbug will now only vibrate to alert you
to incoming calls (This can come in handy
at a movie, a library, or any other location
where a ringer may be a distraction.
May 09, 2018 • Cell Phones
1helpful
How do you move virbrate mode on jitterbug phone back to ring mode
To adjust the volume of the ringer follow these steps:
First, make sure your Jitterbug phone is turned on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the buttonn to decrease the volume. The inside screen will display the ringer volume level, which ranges from Vibrate to Max.
If you need additional help, you can call our Customer Service department at (800) 733-6632. We are available 24/7.
2answers
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
My jitterbug phone is on vibrate how do i get my volume back
First, make sure your Jitterbug phone is on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the ringer volume level. The ringer volume ranges from Vibrate to Max.
2helpful
The ringer doesn't ring, only vibrates. I select "settings" but there is not ringer volume level so I can hear the phone actually "ring', it only vibrates
First, make sure your Jitterbug is open and confirm it's on.
Next, Press the volume button on the outside of the phone below the Outside Display. Press the top of the button to increase the volume and the bottom of the button to decrease the volume.
There are several ringer options available to choose from. If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 and they will walk you step by step through the process.
5helpful
How do you get the jitterbug phone off vibrate and to ring?
If you need additional help, you can call a customer service expert availalbe 24 hours a day, 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
The telephone is on vibrate. How do I return it to ringer?
If you need additional help, you can call a customer service expert available 24 hours a day, 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Message Alert
“if unchecked will only vibrate when the ringer volume is set to vibrate”. Except that I always have my ringer volume set to vibrate (for phone calls) but don’t want the phone to vibrate when I get an SMS. So in the suggestion above, I’d choose ‘never ever ever…’, the middle option would relate to the current ‘unchecked’ setting, and the top option would relate to the current checked setting.
Top One Touch Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
goneforever.
Simon Atkinson
Simon Atkinson
Are you an One Touch Cell Phone Expert? Answer questions, earn points and help others
