Wont turn on red light just flashes? On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Clicking sound, but will not turn on. Samsung flat screen tv
Okay Guys, check on your power-supply PCB (solder-side) for dry soldering and or check on Component side for defective filter capacitors. *both can give you the same symptom.....** If there is a problem on the A/V processor-board, some times tv will not turn on....just take the power-cable coming from the power supply to the A/V processor-board and see if your tv starts "turning on"...if it does , means your A/V processor-board is deffective....... all the best!
our flat screen won't turn on. The blue light stays on all the time. It was not on when we first got it. We have only had it for less than a year. It is so frustrating!!! How do we fix it so it will turn on?
My Samsung flatscreen tv will not turn on. Makes clicking sound and red light goes off and on. TV three years old.
My Samsung flatscreen tv will not turn on. Makes clicking sound and red light goes off and on. TV 18 months to 2 years old.
clicking and wont go on
i have samsung 51 inch plasma the tv turned off by its self i cant turn it on there is no red light on the tv i tryed turninh on with remote and it not on the standby
I had this problem. Turned out my REMOTE batteries were going bad. Who knew ?
I had a similar problem. It wouldn't turn on, and red light was on. Turned out my REMOTE batteries were going bad!
Yeah, I have had my 47 inch flat samsung three years three months and the exact same problem, made clicking sound, first Visio out, then sound. The best Buy people were very flippant and said "Oh yea, that happens to all of them" I will never go to Best Buy again. I just bought a 60 inch in July to add to my two other samsungs. I\'m going to try to remove the back and find the fuse and replace it, if that doesn\'t work then I\'ll try the Power source. Good luck people.
Red flashing light is all I get.
TV has sound/w no picture. Let it stay on for 45 to 60 minutes and turn it off I have a picture. Some times the picture is green, red or blue. Turn the TV of and on again the picture is fine. Sometimes the TV has no sound or picture but 3 flashing lights. Turn it off and on many times there will be sound and no picture and the process is repeated. Any solutions? The TV is about 8 years old.
my tv wont turn on. red light flashes and makes music sound every 5 seconds
we were watching tv and it turned off by itself and then would not turn on. Red light flashes
Okay guys!....just turn the flatscreen off...and.....A. have a look on the solder-side of the Power Supply PCB for 1. Dry solder or B.Defective Filter capacitors on Component side..al the best!
