Dometic NDR 1062 Refrigerator Logo
Posted on Jul 25, 2017
I have a 1988 Southwind RV with a Dometic refrigerater #2801. On gas setting the blinking light does not come on to make the ignitor work. The rod goes through and turns the gas valve on. Where is the switch that turns from electric to gas? There is twelve volts available. Everything has been cleaned. The problem is in the switch wherever the switch is. Do you have a diagram of the switching? Thank You
5 Related Answers
Anonymous
  • 332 Answers
  • Posted on Mar 08, 2010
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Anonymous
  • 51 Answers
  • Posted on Sep 07, 2008
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Anonymous
  • 68 Answers
  • Posted on Mar 31, 2009
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Anonymous
  • Posted on May 08, 2009
SOURCE: Dometic RV refrig light will not go out
Open up the door to the freezer, you will see two black switches upper right just above where the door would be when closed. Flip the first switch, then push the switch on the light in the fridge compartment and the light should go out. Thinking that switch is there to help reduce moisture inside fridge, just got pushed by mistake and light remains on. Hope this helps.
Ron1247
Anonymous
  • Posted on Jul 25, 2009
SOURCE: dometic rm 2801 no elec function working
If it works on gas, there are three parts that can cause this problem. 1. the switch, which is a rotary switch with multiple connections and functions; 2. the thermostat, which sometimes the contacts get arced and don't make connection, and 3 the heating element, which can burn out like a light bulb. You really need a multimeter to test all of these parts to see where the problem lies. If it doesn't work on gas there may be a problem with the cooling unit, which cannot be field repaired.
2answers
Dometic RM2652 Propane Fridge. Can I make my RM2652 Dometic into a manual running fridge on propane?
I have been trying to answer this for over an hour. I moved to a different browser.
did you know this model was the subject of a recall?
Refrigerator Recall ' Dometic.com
https://www.dometic.com > en-us > outdoor > refrigerat...
Please note the following combination of refrigerator model and serial numbers are affected: · Model numbers: NDR1062, RM2652, RM2662, RM2663, RM2852, RM2862, ...
I have searched extensively for spare but they are all marked out of stock or obsolete. You best bet is to call in a gas refrigeration engineer and see if there is a similar part that can be used. It needs to be something automatic.
2answers
Rv 1988 southwind chevy 454
where can i find the fuel pump on a 1988 fleetwood southwind
A dometic #2862 rv refrigerater which is freezing everything
This one is easy your thermostat is gone. You may notice the unit never shuts off.
Typical RV refrigeraters need the unit to be
just mount it for best fit as you can , fairly level, main thing is that the water will be able to drain/evaporate
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
